1994 Honda Del Sol clutch
1994 HONDA DEL SOL
JAIRO_SAN
Transmission problem
1994 Honda Del Sol Front Wheel Drive Manual n/a miles
my shifter feels loose and it grinds when i try to put it in the first 3 gears and once they're in most of the time they wont disengage
Nov 15, 2008 at 10:17 PM
F4I_GUY
  • CAR REPAIR CONTRIBUTOR
  • 3,302 POSTS
Your shifter being loose is most likely caused by faulty shifter bushings down by with the shifter linkage meets the shifter rod. There is a bushing kit you can purchase from honda that can solve that sloppy feel.
If you cannot get into a gear or disengage a car, you may have a hydraulic clutch system failure of some sort. You may have air in the system or a faulty slave or master cylinder. If your hydraulic system is faulty, your clutch will not disengage , thus it will be very difficult for you to get in and out of gear.
Nov 25, 2008 at 5:42 PM
