1993 Honda Del Sol
93 HONDA DEL SOL
  • 1993 HONDA DEL SOL
  • 4 CYL
  • FWD
  • MANUAL
  • 193,000 MILES
93 honda del sol, car won't run unless jumped, if started and drove car will bog down and die out, all eletric dies, has a new alternator, a new starter and a new battery. I put a lot of money into this car alot of money into this car, I really need your help.
Saturday, June 20th, 2009 AT 6:54 PM
KHLOW2008
  • 41,814 POSTS
Hi 93 honda del sol,
Problem seems to be from the charging system.
1. Does the charge indicator light turn on when ignition key is turned to ON?
2. Does the light go off when engine is started?
3. What is the voltage between the battery terminals with engine running?
4. What is the voltage between alternator main terminal and engine ground with engine running?
5. What is the voltage between alternator main terminal and engine ground with engine OFF?
Sunday, June 21st, 2009 AT 2:19 AM
