Faulty oil pressure switch most likely. You can confirm healthy oil pressure by removing the pressure switch and putting a pressure gauge. Re start the car and check for good pressure 80 psi or so. If everything checks ok ground the single wire for the pressure switch and the oil light should go out. If it does replace pressure switch.
SPONSORED LINKS
Monday, February 16th, 2009 AT 7:39 PM
