I took it to a repair shop. They did a fuel flush, changed spark plugs, fuel filter, air filter. It was no better. Now I am told one of cylinders needs replacing and that the car is only running on 3 cylinders. Would this make it stall at low speeds? Any help would be greatly appreciated.
1999 Honda CR-V Stalling on 3 Cylinders
Suggested Repair
Have a leak-down test performed to find why one cylinder is dead. Also confirm every spark plug is getting spark; a failed ignition power pack or distributor-related ignition fault may be the cause.
Conversation Summary
The owner of a 1999 Honda CR-V with a manual transmission reports occasional stalling when slowing or stopping, which became more frequent with a check-engine light and rough running. A shop performed a fuel flush and replaced the spark plugs, fuel filter, and air filter without improvement, then said the engine was running on three cylinders and one cylinder needed replacement. The expert says a dead cylinder can cause low-speed stalling and recommends a leak-down test, checking spark at all plugs, and considering a bad ignition power pack or distributor issue.
