2003 Honda CRV clacking noize from rear of car
85,000 MILES • 4 CYL • AWD • AUTOMATIC
DOUGLASRIVAY
When braking i get a clacking noise from the rear end. The brakes are fine so I think it could be the cv joints on one side or the other.No way to tell without opening up the boots. is the clacking a symptom of bad cv joints. The axels with joints rebuilt are only $90.00 and looks pretty straight forward to replace them. Anything I should know would be helpfull. Thanks, Doug
Sep 24, 2008 at 2:04 AM
KHLOW2008
  • 41,812 POSTS
Hi Doug,
Without proper diagnosis it is difficult to confirm if the noise is from the CV joints.
Is there any other abnormal noises when driving? CV joints should emit some noise during U- turns if they are faulty and not when braking.
You should check the brakes and its component first, it could be the rotor.
Sep 27, 2008 at 3:42 AM
DOUGLASRIVAY
After further testing I think it is the brakes I pulled them apart again and lubed the ereas where the the pads slide on the caliper brackets again and for now the noise is gone. The honda dealer said that the rear brakes on these vehicles have had a history of repairs and that when I installed the last set of pads I should smooth the edges of the pads where they slide on the brackets. That is what they do.Any other ideas would be appreciated. Doug
Sep 27, 2008 at 5:55 AM
