2002 Honda CRV smoke from front seal area
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
LLOYDDUBOSE
AC went out/locked up, I removed serp. belt to drive home to keep from causing more damage to ac/belt, and when vehicle starts , smoke comes from behind the H/Balancer, front seal area, blue oil smoke, I and local mechanics have never seen this before. If front seal is bad,there is only a little oil on front of engine, and when started oil doesnt pour out, just white smoke, havnt removed balancer yet, any thoughts as to cause of smoke from this area, also there is no slack or movement in balancer and no strange noises.
Feb 11, 2009 at 11:40 AM
F4I_GUY
  • 3,302 POSTS
It is probably your front main seal leaking or another seal or cover behind the timing cover. The smoke could just be the oil being burnt off the hot engine, or it could actually be crankcase vapours escaping if the seal is badly torn, but I doubt that. I've only seen this once, and the block had a crack in it.
I would remove the harm. balancer and timing cover(s) and investigate.
Feb 15, 2009 at 6:59 AM
