Check battery voltage, should be at a minimum of 12.1V. If it is lower, try boosting the battery to see if it starts the car.
If not, turn your attention to the starter motor. Check for battery voltage and ignition signal to the starter. Also check the ground cable coming off the transmission to chassis.
SPONSORED LINKS
Thursday, March 11th, 2021 AT 6:43 PM
