1987 Honda CRV electrical problem
CHILLY40
1987 Honda CRV 4 cyl Automatic 120000 miles
My car shuts off while driving. My mechanic checked all wires and reports he cannot find anything. He reports it is very difficult to figure out an electical problem. He took out the alarm "box" and wires as its was very hot everytime the car was running. That IS NOT the problem because the problem is still happening. He thought it might be the key...that IS NOT the problem. I wondering if anyone has heard of this problem particularly in Honda CRV's because then we might know where to begin. It is like finding a needle in a haystack. Once the car shuts off, all you have to do is turn the key off and then back on and it runs again right away.
Jul 25, 2010 at 1:48 AM
  • 31,937 POSTS
Hi there,
Did they run a scan to check for any fault codes, not all fault codes will set a MIL.
mark (mhpautos)
Jul 25, 2010 at 1:50 AM
EDWARD.S
  • 166 POSTS
Hi,First have The Computer Checked For Codes.And Have The Fuel Pressure Checked, If Nothing Is Found , Then I'd Look At the Ignition System . The Distributor Goes bad In Hondas. Also Another Failure Is The Power Relay.But I'd Start At The Distributor , Very High failure rate.
Hope This Helps You,
Good Luck
Edward S.
Jul 25, 2010 at 2:00 AM
