motor mount bolt problem
HONDA CIVIC
TOM4691
Help I am replacing the motor into a 1993 civic. During the operation I attempted to remove the lower engine mounts bolts and with an impact gun. The bolts started to loose then the internal frame nut broke free and it happened to one bolt/nut on each side. I can cut the bolt off but how to you attach the new motor mount? It was suggested to me that I could drill an access hole in the top of the frame?
May 2, 2006 at 7:28 AM
BRUCE HUNT
  • 3,754 POSTS
Did you ever resolve this?
May 9, 2006 at 4:27 AM
TOM4691
The repair; I cut off the old bolts with a cutoff tool and then I drilled a hole in the top of the frame only large enough for an Allen head cap screw and lock washer. Dropped the bolt into the frame and put the washer/nut on the bottom side of the frame.
I talked to a friend who had the same problem and he drill the hole large enough to fit a socket to accommodate the nut that was in the frame
May 11, 2006 at 2:07 AM
