2003 Honda Civic Overheating Fans
Suggested Repair
The cooling fan switch is in the thermostat housing. With the ignition on but the engine not running, jump the switch connector; if the radiator fan runs, replace that switch. If it does not, check the radiator fan, fuse, and relay. You can also apply 12 volts directly to the radiator fan, not the A/C fan, to confirm the motor works. The switch is typically on the front or right side of the engine; follow the wiring harness to locate it.
Conversation Summary
A 2003 Honda Civic EX 1.7L overheats, especially at low speed or idle, after the thermostat, coolant bleed, and radiator cap were addressed. The owner believes the cooling fans are not coming on and asks where the fan sensor is. One reply says it should be on the front or right side of the engine and suggests testing the radiator fan with 12 volts. Another identifies the thermostat-housing sensor as the cooling fan switch and recommends jumping its connector with the ignition on; if the fan runs, replace the sensor, otherwise check the fan, fuse, or relay.
