2001 Honda Civic Rough Idle Vibration
CENTGENT238
i have a 2001 honda civic lx with 133000 miles on it.
when i start my car it starts fine then idles fast and then goes really low and shakes like its going to die before leveling off. the car drives fine but when i stop and idle i notice the passanger seat shakes. when it doesn't shake i can feel vibration in my seat and in the sterring wheel. i recently replaced the spark plugs and now the problem is worse. the longer idle the more i can feel something shaking in the engine. plus there is a constant clicking noise coming from somewhere around the belts, and i swear after i drive for awhile i can smell something overheating in the engine. what could be wrong, and how much would it cost to fix it?
Mar 24, 2007 at 4:07 AM
2CARPRO JACK
  • 11,533 POSTS
Hmmm. Go back to the tune up, got worse? did you use OEM parts or Bosch platinum plugs? Remove plugs and double check the gap, recheck firing order.You could have created your own problem by installing a bad plug.The original vibration...... have the motor mounts checked? Also might want to clean out the throttle bore with a rag and a little carb spray, that will probably help the low idle problem
Mar 25, 2007 at 1:01 AM
Suggested Repair
Recheck the new spark plugs for correct gap and firing order, and confirm they are suitable OEM-style plugs rather than a bad or mismatched plug. Have the motor mounts inspected for the vibration, and clean the throttle bore with a rag and carburetor cleaner to address the low idle.
Conversation Summary
The owner of a 2001 Honda Civic LX with 133,000 miles reports a fast idle that drops very low and shakes, vibration felt in the passenger seat and steering wheel, a clicking noise near the belts, and a possible overheating smell. The symptoms worsened after spark plugs were replaced. The expert advises rechecking plug gap and firing order, verifying the plugs used, inspecting motor mounts, and cleaning the throttle bore.
