1991 Honda Civic Brake Pedal to Floor
WEBBEYOND2000
  • 6 POSTS
I have a 91 Honda Civic DX 1.5L (Stick-Shift) with 188,000 miles.
Problem:
1. The first problem I encountered while driving was when I brake, the car did not stop as it suppose to. Instead the car was only slowing down and the brake pedal slowly goes to the floor. This happend a couple of times when I tried to brake. I drove the car to a parking lot and stepped on the brake pedal a couple of times and was able to get the brake working again.
2. After I pumped the brake pedal several times and got the brake pedal to work, I noticed the brake light from the dashboard turn-on and I was not able to get it turn-off.
Does anyone know what the problem is? Thank you in advanced to answer my question! :cry:
Aug 12, 2007 at 4:26 PM
BRUCE HUNT
  • 3,754 POSTS
First of all the clue should be that the pedal disappeared and you had problems stopping. If you continue to drive the vehicle you are crazy. This car has a failing master cylinder or slave. Please fix it soon!
Aug 13, 2007 at 2:45 AM
Suggested Repair
Do not continue driving the car. Have the brake hydraulic system inspected promptly, focusing on a failing master cylinder or related slave cylinder, and repair it before driving again.
Conversation Summary
The owner of a 1991 Honda Civic DX reported that the brake pedal slowly sank to the floor and the car only slowed instead of stopping. Pumping the pedal restored braking, but the dashboard brake light then stayed on. The expert said this indicates a failing master cylinder or slave cylinder and advised repairing it immediately rather than continuing to drive.
