89 civic sunroof won't close - need temp solution!!!
BWAARD
just bought an 89 civic to use as a winter car. I opened the sunroof today but it got stuck in the open position.
When I push the 'close' button nothing happens (no noise, movement, etc) but when I push the 'open' button is makes noise. From my limited car knowledge I'd say the closing motor is broken.
Is there a temporary solution (besides a tarp!) so that I can just have it closed until I get to my mechanic?
thanks!
Oct 22, 2007 at 1:43 PM
BRUCE HUNT
  • 3,754 POSTS
Up on the ceiling should be a plastic cap. Pull the cap off and inside should be an allen screw that enables you to manually close the sunroof.
Oct 23, 2007 at 2:30 AM
BWAARD
you are absolutely right...
in my tool kit in the trunk was an 's' shaped tool that fit perfectly and cranked it closed.
thanks!
Oct 23, 2007 at 6:58 AM
