2004 Honda Civic Temp guage is high (3/4 high), always cold
130,000 MILES • 4 CYL • FWD • AUTOMATIC
TRUTHSEEKER
Yea, thanks for reading! As the subject says the temperature guage is always above mid point when the heating or cooling system is on. As a matter of fact, no matter what I choose hot or cold, the systen blows cold air. The temperature is always a bit above mid point on the guage when all air cooling or heating activities have ceassed. I checked the cooling liquid for the radiator and it is lowwwwwww. So what could this be? Do you need more information?
Jan 13, 2010 at 8:33 AM
F4I_GUY
  • 3,302 POSTS
You have a coolant leak somewhere. You are getting no heat inside the vechile because you are low on coolant. Have a pressure test done to help pinpoint the source of the leak.
Jan 15, 2010 at 11:43 PM
