2003 Honda Civic Whining in reverse and rattle in front rig
88,000 MILES • 4 CYL • FWD • AUTOMATIC
OSUJAMS_11
  • 7 POSTS
1. When I go in reverse I notice a whining noise much more than just a normal sound when going in reverse. It isn't there when I go in drive or neutral, only in reverse. I haven't changed the brakes recently ever. I just put new tires on it about a week ago. About 6-8 months ago the Honda dealership did replace the front struts due to a front end rattle, which resolved that issue.
2. Also, in the front passenger side of the vehicle there is a rattle at about 50 mph. It sounds like a loose screw rattling around in a jar. The sound is very slight, and it took my wife a while to convince me that it was even happening, but it is definitely there. When I apply the brakes the rattle goes away immediately. What could these problems be?
Nov 12, 2009 at 5:49 AM
F4I_GUY
  • 3,302 POSTS
1) Whining is perfectly normal in reverse, this is due to the cut of the reverse gears.
2)You have loose brake pads, calipers or rattle clips.
Nov 12, 2009 at 1:45 PM
OSUJAMS_11
  • 7 POSTS
Can I just tighten these or do I need to replace them?
Nov 12, 2009 at 11:17 PM
