2003 Honda Civic Can't insert key into door lock
ERICKCLAVIJO
Other Category problem
2003 Honda Civic 4 cyl Wheel Drive Type unknown Manual 50000 miles
The key will only go in a little way into the lock on the driver's side door. At that point I encounter resistance and cannot go any further. Every once in a while, I get lucky and the key slides in. The same key works fine with the passenger side door.
Jan 13, 2008 at 9:37 AM
BLACKOP555
  • 10,386 POSTS
you may havea frozen lock if you live in a cold place or you may need a new lock cylinder.
Jan 13, 2008 at 10:53 AM
