2002 Honda Civic 4 cyl Front Wheel Drive Manual 150K miles
Car blows cold air even though temp gauge shows warmed up. Doesn't matter if on heat or defrost and doesn't change even if A/C compressor is off. Also doesn't matter if on recirculate or fresh air. Then just all of a sudden it will switch over to heat and blow hot air. Then works until started cold again. Sometimes it seems to help the changeover if the car is reved up a little. Thanks for the help
SPONSORED LINKS
Monday, December 7th, 2009 AT 4:14 PM
