Hi dbaas,
Honda transmissions are very sensitive and if incorrect fluids were used, it can cause irreversible damages.
If the fluid level is correct with no trouble codes, I would say the trans is failing and would require rebuilding.
When transmission is cold, they tend to leak internally along presure points and after warming up, the sealing becomes better thus the shifting improves. This is due to aging of the O rings.
SPONSORED LINKS
Friday, January 15th, 2010 AT 11:44 AM
