2001 Honda Civic Car has random transmission issues
63,500 MILES • 4 CYL • FWD • AUTOMATIC
ADAME18
Hi, I have just recently started having transmission issues(about 3 days), but they come at random times. I first received the problem when I was trying to get my car out of snow. I was putting my car in reverse and drive to let it free. I made sure I gave my car appropriate time and did not aggressively use the gas. After the check engine light came on and I could smells something burn. Now the check engine light will come on every time my car starts to have problems, but after the problem goes away the light switches off again. The problem I have is the car randomly has trouble going from second to third gear and I believe there is slightly a hard push from gear to gear. I believe the problem happens after longer periods of driving. Most of the time it shift correctly, but randomly it have issues. My only thought is it could be a sensor. Any help would be greatly appreciated. Thank you.
Dec 29, 2008 at 4:04 PM
KHLOW2008
  • 41,812 POSTS
Hi adame18,
Since the CEL came on, there would be freeze frame data recorded in the PCM and I would suggest getting a scan done to find out the code before we proceed further. The exact error code would give us some idea what is wrong and you can get the scan done free at your local Autozone outlet.
Dec 30, 2008 at 4:24 AM
ADAME18
I went to Auto Zone and the computer said I need a throttle position sensor. Is there system reliable or should I go to a mechanic and ask them.
Jan 3, 2009 at 9:44 AM
KHLOW2008
  • 41,812 POSTS
Hi adame18,
The reading should be correct and confirms an error with the TPS and it could be faulty or out of adjustment. A mechanic would be able to test the TPS.
Jan 3, 2009 at 7:28 PM
