2001 Honda Civic
JHON ARENAS
  • 2001 HONDA CIVIC
Computer problem
2001 Honda Civic 4 cyl Two Wheel Drive Automatic 65.000 miles
i have a honda civic 2001 coupe
i have a problem with the car just when the car get normal temperature after bber driving like 15 or 30 min is just lost his power it doesn't run more than 20 m/h and the revolution just can go to 2000 or 3000 it doesn't have any wear song and the engine either I press the accelerator and the car just keep going slow but the transmission change the gear normally and very smooth the same with the engine.
but after like 2 or 3 hours when it get could again works normally for another 15 or 30 minutes and the problem comes again. Everything is original engine and transmission.
Thursday, July 29th, 2010 AT 12:29 AM
Lack of acceleration, chugging, hesitating, bogging etc. Could be caused by one of the following below:
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Thursday, July 29th, 2010 AT 12:45 AM
JHON ARENAS
Okay thank you so much guys
Thursday, July 29th, 2010 AT 1:32 AM
