Whenever I get up to 65 or 70mph my rpms will drop an my car wont get up to no more then 20mph before it cuts off
Wednesday, July 16th, 2008 AT 11:35 AM
KHLOW2008
MECHANIC
Hi ron6383,
What happens after it cuts off? Can it be restarted?
Is there any check engine light showing?
SPONSORED LINKS
Wednesday, July 16th, 2008 AT 11:55 AM
RON6383
MEMBER
Yes it will restart, an yes theres a check engine light that comes on. Ive had it on the machine an it said timing so ive had a timing belt an waterpump put in, an even had the crank sensor replaced but its still doing the same thing
Wednesday, July 16th, 2008 AT 1:11 PM
KHLOW2008
MECHANIC
Hi ron6383,
Let me know the error code to understand the situation better.
Thursday, July 17th, 2008 AT 8:40 AM
RON6383
MEMBER
I dont have the codes but if he didnt put a honda crank sensor on my car would it cause it to drop rpms an not pick up speed like its doing. What are the symptons for a bad crank sensor
Thursday, July 17th, 2008 AT 11:21 AM
KHLOW2008
MECHANIC
Hi ron6383,
If the sensor had been replaced with a different type, it could cause difficult starting, misfiring, poor acceleration and idling.
Check the code again and see what it is.
Your problem could be an O2 sensor or throttle position sensor fault.
SPONSORED LINKS
Thursday, July 17th, 2008 AT 12:02 PM
RON6383
MEMBER
Thank you because that what its doing once the check engine light comes on it start having problems idling, an it wont get up to no more then 20mph thank you
