2000 Honda Civic Speedometer stuck at 20 mph.
87,500 MILES • 4 CYL • FWD • AUTOMATIC
TOPGUN1226
  • 29 POSTS
The speedometer on my 2000 Civic goes to 20 mph immediately (car is in Park) upon startup. Pressing the trip odometer reset several times will make the needle eventually drop to 0 mph and operate properly for the remainder of the trip.
The transmission doesn't race (it operates normally) and cruise control can be set beyond 20 mph - so I know that I'm definitely operating properly.
When the needle is stuck at the 20 mph point, the odometer does not operate. After you reset the needle by pressing the reset button several times, the odometer starts operating again.
I think this is a display issue at this point. The local Honda dealer said I need to replace the speedometer head, and that they'd have to order the part (take about a week to get in).
Does this sound accurate? What exactly does the trip reset button do that is starting to make it work?
Thanks,
MC
Jul 29, 2008 at 7:11 AM
KLSHIEL
  • 163 POSTS
This does sound accurate, I would have said either the connection behind the speedo or the speedo itself. What is happening is the gauge is getting a bad signal, or it is looping the signal internally. Since your cruise works fine it is behind or in your dash. When you hit reset it stops power and then alows it again when you do this several times the surges straighten out the signal.
Apr 7, 2021 at 5:50 AM
