2000 Honda Civic Intermittent A/C
BIGC78
  • 2000 HONDA CIVIC
  • 4 CYL
  • FWD
  • 130,000 MILES
A/C will work fine and blow cold air during the morning or when it isnt very hot outside(85 degrees or so and below) When it has been sitting in the sun and the temp is 90 and above as it has been the last week or so the a/c will blow hot and will not get cold. The freon level is normal. Sometimes when driving down the road if the a/c is working it will go out and start to blow warm and give off a musty smell. Any ideas?
Thanks
Monday, June 9th, 2008 AT 4:27 PM
KHLOW2008
  • 41,814 POSTS
Hi bigc78,
Musty smell means the heater is in operations.
Check for air mix problem, like an out of adjustment air mix valve control cable.
Check the AC thermostat too.
Tuesday, June 10th, 2008 AT 11:24 AM
