1999 Honda Civic Speedometer and accelerator
162,000 MILES • 4 CYL • 2WD • MANUAL
BRIDGETMORAG
I recently had my clutch replaced on my 1999 Honda Civic DX hatchback five speed manual. Since then, my speedometer does not seem to be working. When I am pressing on the accelerator, the speedometer hovers around 25 miles an hour, regardless of what my actual speed is or what gear I'm in. I only get somewhat of an actual reading when I'm braking, pressing on the clutch, or in neutral. Is this a separate issue with my speedometer, or is this related to my clutch replacement?
Jan 15, 2009 at 3:07 PM
KHLOW2008
  • 41,812 POSTS
Hi bridgetmorag,
The speedometer receives its signal from the tranmission mount speed sensor and during installation, the sensor could be installed incorrectly. Check the connectors. It could be a faulty speed sensor, it sometimes gives way when subjected to vibrations incurred while removong and installing the transmission.
Apr 7, 2021 at 5:52 AM
