It is hard to diagnose a noise, especially online. Describe the noise. Is it constant, or doe it change with engine rpm. Is it more of a squeak, clatter, knocking, etc? Can you tell which area of the engine the noise is coming from?
When did it start? Did you do something different, or what were you doing prior to the noise? What have you done since then?
Anything that you can elaborate will help us help you.
SPONSORED LINKS
Saturday, November 15th, 2008 AT 12:07 AM
