1998 Honda Civic CVT
138,000 MILES • 4 CYL • FWD • AUTOMATIC
LADYNEEDSADVICE
OK
So I bought a civic and it has a bad CVT the variable transmission , I got HOSED but that's another story.!!
The transmission surges till about 45 mph, during deceleration (when I slow to a stop the rpm's surge and the car seems like its going to stall but when I put it in neutral its fine and it surges till about 45 miles per hour during acceleration. My mechanic says to buy a used one (transmission) or replace the starter clutch, starter control valve and the TCM. My understanding is all of this would be the price of a new one, is that so? No more money to buy another used car, I'm trying not to stress about the $$. So many people are comming at me with what to do, now I'm confused.
Please help me, with your best advice,
Thanks in advance
Ladyneedsadvice PS I donated more $$ in a separate transaction.
Jan 26, 2009 at 2:26 AM
  • 75,988 POSTS
What is CVT stands for-I don't get this one in order to help please be specific is to exactly what the problem is
Jan 26, 2009 at 3:11 AM
LADYNEEDSADVICE
My question is how much should it cost to rebuild my transmission.
My mechanic says the parts to be replaced are; start clutch assembly, start clutch control valve and the TCM control unit. This rebuild information was taken off the internet based on the symptoms. The idle fluctuates between 500 and 1500 RPM's when engine cold, it shudders when accelerating from a stop and slowing down to stop. It feels like the car will stall when in drive when the car is stopped st a light.
It states 6 hours labor but no prices for the parts.
Jan 27, 2009 at 12:55 AM
  • 75,988 POSTS
Do you have a check engine light or has flashed-if so get the computer scanned for code/s
A badly needed major tune-up will affect the operaton of the transmission. At park position while engine is idling the transmission should not caused the idle to surge. I recommend you have the fuel pressure, idle air control valve and throttle position sensor checked out
Jan 27, 2009 at 5:26 AM
