1.) The problem is electrical and
2.) It's not the fuel pump (if it were, the dash wouldn't go dark).
The battery clamps are tight, all fuses and relays seem to be seated (both under the hood and beneath the dash). It crossed my mind that this could be the ignition switch failing, but that also wouldn't explain the momentary dash darkness--the dash illumination is independent of the state of the ignition switch.
I have a degree in electrical engineering, so I 'm qualified to do any level of electrical troubleshooting that may be required. I'm just hoping for some advice that can point me toward the right areas.
Tuesday, March 17th, 2009 AT 10:12 PM
