1997 Honda Civic water evaporates
DJAVILAS
Engine Cooling problem
1997 Honda Civic 4 cyl Two Wheel Drive Automatic 140k miles
i have a 97 honda civic ex the antifreeze is evaporating i have to add water every 60 miles. it has no leaks anywhere. i checked the radiator, all hoses, even the heater core. it does not produce a smell. the coolant just desappears with no trace and there is no coolant in the ingine or transmition fluid. where is the water going? please help?
Feb 14, 2010 at 5:06 PM
KHLOW2008
  • 41,812 POSTS
Hi djavilas,
There must be a leakage somewhere and a pressure test would reveal where it is.
Is the recovery tank over flowing or depleting as well?
Feb 18, 2010 at 5:37 AM
DJAVILAS
as a matter of fact the water leaks thru the over flow and i just notice the cooling fan is not working. thanks for your help you have any more suggestions for me? i will pressure test it
Feb 23, 2010 at 3:52 AM
KHLOW2008
  • 41,812 POSTS
If the cooling fans are not working, it would cause the coolant to over flow through the recovery tank.
Other possible causes are :
1. Bad radiator cap.
2. Blown head gasket.
Get the cooling fans system checked first.
Feb 23, 2010 at 4:09 AM
