1997 Honda Civic Highway surge irratic idle.
OPNANTFAN
  • 1997 HONDA CIVIC
Engine Mechanical problem
1997 Honda Civic 4 cyl Front Wheel Drive Automatic 100k miles
Hello, my Civic Has idle surge after it has warmed up. It started after the car had been sitting for about 5 months. Turning the AC all the way up seems to stop the surging but it still has a high idle. It also has highway surging. It feels like the car will only speed up or slow down, not maintain a constant speed when the AC is off. There is no check engine light. I've bled the cooling system and cleaned the IACV as well as inspected hoses and intake for vacuum leaks. So. What do ya think. Appreciate any advice!
Thursday, July 1st, 2010 AT 10:29 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking, fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Friday, July 2nd, 2010 AT 12:08 AM
