1997 Honda Civic hesitation at low RPMs
W003RER
  • 1997 HONDA CIVIC
I am getting a very slight hesitation (jerkiness), almost a misfire but I wouldn't say it was that severe. I gave the car a tune up and it didn't fix the problem. The hesitation occurs at low RPM and sometimes only once or multiple times as I accelerate. Once I reach speed it stops. It also occurs when the motor is under load. Is this a typical distributor problem, or could it be something else, clutch slipping, MAP Sensor problem, etc. I am taking it to a Honda dealer but want to have a heads up on some of the responses I might get from the dealer mechanic.
Thanks
Ran Raider
Wednesday, June 21st, 2006 AT 10:45 AM
BRUCE HUNT
  • 3,754 POSTS
The very first thing I suspect is the plug wires. That is the very problem that surfaces with a bad set of wires. Try switching with another to check or replace them.
Wednesday, June 21st, 2006 AT 4:11 PM
KWONG
  • 7 POSTS
I have a similiar problem with my honda civic also an it only has 72000 miles what did the dealer say because I am taking my car to the dealers also.
Monday, July 31st, 2006 AT 8:38 PM
94BOWDEN
  • 33 POSTS
Pull out your spark plugs to see if they are fowled up at all if so then your running to rich if they are black and to lean if they if they are white. You can fix alot of problems by looking at your spark plugs. They give you an idea of whats going on inside your motor. Check them and write back
Thursday, August 3rd, 2006 AT 10:09 AM
JAYT
I have a 99 Civic with the same exact problem. The car died upon acceleration mid-intersection. Turned out that the ignition coil had burnt out, literally. After replacing, the car started again but the hesitation/misfire problem was noticed for the first time. I replaced the cap and wires. The plugs look good. The problem is still there, but usually only occurs after the engine warms up. Any advice would be appreciated.
Sunday, August 13th, 2006 AT 1:53 PM
