1997 Honda Civic check engine light
TRACYAP
  • 1997 HONDA CIVIC
  • 4 CYL
  • MANUAL
  • 140,000 MILES
The check engine light has been on, had new alternator-battery replaced. While driving the other night I was loosing power, light dimming ect. Won't start
Tuesday, December 2nd, 2008 AT 10:08 AM
F4I_GUY
  • 3,302 POSTS
You may have two possible faults here.
An alternator, battery problem will not illuminate the CEL.
Does the vehicle crank? Or not crank? If it cranks you can go into running checks for fuel and spark. If they are both present, I would scan the ECU and that may give you some insight into what is acting up.
If it doesn't crank, you may have left a wire loose or the mechanic did when they replaced the battery/alternator. Check your connections first.
Let me know what you find so I can further assist you
Tuesday, December 2nd, 2008 AT 4:40 PM
TRACYAP
Thank you, it seems to have been a corroded wire to the alternator. Cleaned it up and all power is full again.
Wednesday, December 3rd, 2008 AT 12:05 PM
F4I_GUY
  • 3,302 POSTS
Great news! Glad you resolved it. Make sure you go over all your power and grounds as well, you may prevent a future problem by cleaning them now.
Wednesday, December 3rd, 2008 AT 4:39 PM
