1997 Honda Civic battery dies overnight
YVETTE6
  • 1997 HONDA CIVIC
Electrical problem
1997 Honda Civic Front Wheel Drive Manual 100000 miles
Hi - My 1997 manual honda civic battery is dying when it's parked overnight. The mechanic charge-tested the battery and says it's in good shape (over 70%) and it's a newer batter - about 1.5 years old. The alternator is also okay, he says, because the battery charges while I'm driving the car - just dies when parked. About 1.5 years ago I got a new battery when the electrical system failed - while driving, all my radio and lights went off and a few seconds later the car stopped and the battery had died. My mechanic at the time identified a faulty O2 sensor and blown fuse and I got a new sensor, new battery and new alternator. This last winter I stored the car in an unheated garage over the winter for 5 months and did not start it regularly but when I started it 3 weeks ago it went fine and I've been driving it regularly for 3 weeks for long drives with no problems. Then the other morning I went to start it and the battery had died. This time the electrical system (radio etc) still works and it doesn't seem like the same problem as before, but there is still something going wrong w/ the electrical system somewhere, according to my mechanic. He says there is some kind of parasitic drain on the system that's causing the battery to die overnight but that it might take a long time to detect the exact circuits that are causing the problem. Do you have any experience with this or suggestions where to start?
Tuesday, March 23rd, 2010 AT 9:02 PM
Hi yvette6, Welcome to 2 carpros and TY for the donation.
Do below battery drain test:
https://www.2carpros.com/forum/automotive_pictures/12900_parastic_draw_1_205.jpg
Tuesday, March 23rd, 2010 AT 9:39 PM
YVETTE6
Thank you very much for your reply - for some reason it's inside a smaller window and I can't read it all - could you re-post it - thank you.
Wednesday, March 24th, 2010 AT 9:33 AM
Give me your email addy and we'll see if its buffed up
Monday, March 29th, 2010 AT 2:50 PM
YVETTE6
It's all okay - I think the info I can see there is good. Thanks for your help.
Tuesday, March 30th, 2010 AT 12:19 AM
2 LINSEY
  • 287 POSTS
Hi yvette,
Thank you for using 2CarPros. Com. We appreciate your donation and look forward to helping you in the future.
Thursday, April 1st, 2010 AT 5:34 PM
