1997 Honda Civic
VTEC22
Shakes or Wobbles problem
1997 Honda Civic 114200 miles
why does my car shake when im driving, also my engine shakes and when in park it shakes too....????
Jun 29, 2009 at 9:36 AM
TED-E-DEE
  • 109 POSTS
Several things can cause your trouble. Lets start with problem in park. This can be caused by a low idle problem. Also, you need to check motor mounts & trans mounts. They have rubber bushings inside the metal frme that can be deteriorated or cracked. The metal frme can be broke also. As for problem while driving, this can be caused also by motor/trans. mounts or you may have another problem. Check tire balance, ball joints, tie rods & ck. everything for breaks or looseness. Basicly, ck. the whole frt. end susp. & steering. Start w/easy things 1st. Inner axle shaft joints have been known to wear out inside & cause vibration. Good Luck.
Jun 30, 2009 at 7:39 AM
