1996 Honda Civic overheating
ROBIN B
  • 1996 HONDA CIVIC
Engine problem
1996 Honda Civic 6 cyl Wheel Drive Type unknown Manual 150, 00 miles
my car is overheating and water was spraying on the engine. I repaired a crack in the radiator so there is no more water but it is still overheating. I now notice it looks like the fans are not coming on. I checked the fuses and the relay but they all seem to be ok. What do you think?
Sunday, December 16th, 2007 AT 6:21 PM
  • 31,937 POSTS
Pressure test the cooling system to make sure that there is no more leaks. There is a temp sensor for the fans, if it is faulty the fans will not come on, (i will have to re post re the location of the sensor as I can not get into the data base just yet) Check things like thermostat and radiator cap. Worst case may have a blown head gasket from overheating and coolant loss.
Mark (mhpautos)
Sunday, December 16th, 2007 AT 7:14 PM
