1996 Honda Civic LAF Sensor
1996 HONDA CIVIC
125,002 MILES • 4 CYL • FWD • MANUAL
DAVID BONNEY
My car does't pull when you accelerate.
I checked the fault code manually and it gave code fault 48.
I googled and the answer was LAF sensor(Lean Air Fuel)
I want to know what LAF sensor is and where I can locate on my car
Mar 2, 2010 at 11:28 PM
F4I_GUY
  • 3,302 POSTS
There is no such thing on the vehicle. What you have is a lean air fuel mixture code, this means that you are running lean (more air, than fuel).
Items to check:
-vacuum leaks
-o2 sensors
-MAP/IAT sensor
-exhaust leaks
Mar 4, 2010 at 5:58 AM
