1996 Honda Civic Engine cuts out at low RPM sometimes but n
MWATERS
MEMBER
1996 HONDA CIVIC
4 CYL
FWD
MANUAL
150,000 MILES
I have a 96 civic that hesitates at low RPMs it is most noticeable as you start out in 1st or shift into 2nd. When you try to accelerate it hesitates and stumbles till the RPM's get up around 2000 then no problems. It acts the same in 3rd if you shift too soon and lug the engine. The check engine light doesnt come on and I have changed the Fuel filter. The car is fuel injected
Any ideas.
SPONSORED LINKS
Monday, February 1st, 2010 AT 7:38 PM
2CARPRO JACK
MECHANIC
Sounds like it could be ignition related, have you had it tuned up yet and if so what parts did they use? Low speed misfires are usually caused by old/faulty ignition parts (plugs, wires, cap, rotor)
Tuesday, February 2nd, 2010 AT 8:26 AM
MWATERS
MEMBER
I havent done a tuneup yet. I was trying to decide which direction to go. I will do the plugs, cap & rotor and see if it improves.
Thanks
SPONSORED LINKS
Tuesday, February 2nd, 2010 AT 9:18 AM
2CARPRO JACK
MECHANIC
Let me know how it goes. Be sure to use good parts too. Cheaper isnt better
