1995 Honda Civic IDLE PROBLEM
CIVIC
  • 1995 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 112,000 MILES
ITS A CARBURETER AND IV HAD IT ADJUSTED BUT THE REV IS AT ABOUT 800 THEN WHEN IV DRIVEN IT FOR ABOUT HALF HOUR IT GOES TO LIKE 950 OR 1000 RPM WOTS AND EVEN IF THE CAR IS WARM AND I TURN IT OFF AN THEN START IT AFTER A WILE THE REV WILL STICK AND 1500RPM AND THEN WHEN I TAP THE PEDAL IT WILL COME DOWN
Saturday, August 30th, 2008 AT 5:07 PM
KHLOW2008
  • 41,814 POSTS
Hi CIVIC,
You need to check the vacumn hoses and diaphragms, some could be leaking or the controlling solenoids are stuck/faulty.
Worn or sticky linkages could cause the problem too.
Sunday, August 31st, 2008 AT 2:00 AM
