1994 Honda Civic car died
SMITTYCOOL
  • 1994 HONDA CIVIC
  • 4 CYL
  • FWD
  • 247,000 MILES
Was driving and car went dead, and the window will not work unless I turn the car in the crank position and have to keep it in the cranking position to keep it running.
Friday, September 3rd, 2010 AT 2:45 PM
KHLOW2008
  • 41,814 POSTS
Hi smittycool,
The ignition switch is bad and has to be replaced to rectify.
Friday, September 3rd, 2010 AT 3:31 PM
EK20
  • 7 POSTS
Its the ignition its bad!
Saturday, September 4th, 2010 AT 2:38 AM
NAPSTER_289
Have you tried to check on the Ignition control module and coil? Heat may have caused this ICM and coil to breakdown. If it is bad then it may have caused your car to die so try to go on a shop and replace it.
Tuesday, September 7th, 2010 AT 7:57 PM
