My 94 civic seems to bog when I press the gas and bogs until at higher RPMS?
Saturday, March 14th, 2009 AT 4:12 PM
F4I_GUY
MECHANIC
When is the last time you did a tune-up? You may just have worn out spark plugs, or another tune-up item is on it's way to failing and causing a slight mis-fire.
You may also have a vacuum leak. What does your vehicle idle at when it's fully warm?
SPONSORED LINKS
Sunday, March 15th, 2009 AT 8:42 PM
SSOCAL05
MEMBER
I had just bought it so wasnt sure about the plugs. I pulled them out they were bad, replaced tham and that fixed it now it runs like new well almost, Thank you for your reply.
Tuesday, March 17th, 2009 AT 1:17 AM
F4I_GUY
MECHANIC
Glad I could help.
You may also want to think about doing a full tune-up. Ignition wires, cap, rotor, pcv valve, fuel filter, air filter, etc.
