1993 Honda Civic wants to stall
KOWALCZYK78
  • 1993 HONDA CIVIC
  • 4 CYL
  • FWD
  • 172,000 MILES
My problem is when I have less than a half of tank of gas and it is about 90 degrees or higher the car wants to stall at idle. When it is cooler out the car runs just fine. My buddy told me that since it is a closed loop fuel system, that there is a one way valve connected either in route with a rollover valve or in the gas cap, that is not letting air back into the gas tank. Therefore when it is hot out and not much fuel in the tank, the fuel pump works too hard and shuts off. Im not quite sure where to go with this one. Any info would be helpful. Thanks.
Wednesday, July 22nd, 2009 AT 8:27 AM
F4I_GUY
  • 3,302 POSTS
Common issue,
It is most likely the fuel pump main relay. Try replacing that first. If not, you may need a fuel pump.
Thursday, July 23rd, 2009 AT 4:22 PM
KOWALCZYK78
But why would it do it only when it is hot out. About 90 degrees +. Any other time it is fine
Friday, July 24th, 2009 AT 3:11 PM
