1993 Honda Civic Car Idle
MONKEY BRAWLER
  • 1993 HONDA CIVIC
  • 4 CYL
  • FWD
  • MANUAL
  • 175,000 MILES
I just had to replace the head of my 93 Civic because the camshaft snapped, after I replaced the head the idle now revs up and down. There is also a screech comming from the alternator belt I believe, I have tried tweeking the distributer with no luck. I would like to not take it into a shop because I am "automotively Challenged" and working to learn.
Saturday, July 5th, 2008 AT 2:07 PM
BLACKOP555
  • 10,371 POSTS
For the squeeking, remove the drivebelt, does it stop?
As for the idling make sure you have NO vaccum leaks, to check for them use a can of starting fluid or carb cleaner and spray around the manifold and the air hoses, does idle chagne?
Saturday, July 5th, 2008 AT 4:43 PM
KHLOW2008
  • 41,814 POSTS
Hi Monkey Brawler,
Make sure coolant level in radiator is full.
Saturday, July 5th, 2008 AT 10:27 PM
