1993 Honda Civic
JLOZAN6
  • 1993 HONDA CIVIC
  • 4 CYL
  • 178,000 MILES
I JUST BOUGHT A 93 CIVIC AND WHEN I TURN IT ON IT WONT STAY ON UNLESS I STEP ON THE GAS. THEN AFTER THAT I HAVE THE PEDAL ALL THE WAY TO THE FLOOR AND IT DOSENT ACCLERATE. AND IF I LET GO OF THE GAS IT DIES. I WENT TO A MECHANIC AND HE TOLD ME IT WAS THE THROTTLE BODY AND I PUT IN A NEW ONE AND IT STILL DOES THE SAMETHING.
Monday, June 30th, 2008 AT 8:37 PM
Inspect and test the idle air control valve and throttle position sensor-
Monday, June 30th, 2008 AT 8:44 PM
JLOZAN6
HOW CAN I TEST THE VALVE AND SENSOR
Monday, June 30th, 2008 AT 8:47 PM
Try cleaning out the idle air control and also test the TPS closed and WOT voltages-refer to repair manual.
Monday, June 30th, 2008 AT 9:22 PM
KHLOW2008
  • 41,814 POSTS
Hi jlozan6,
On top of what rasmataz has suggested if they don't work, I would suggest checking the fuel pressure, ignition timing, valve timing and compression.
Tuesday, July 1st, 2008 AT 10:53 AM
