1992 Honda Civic Radiator has brown liquid in it and horn d
1992 HONDA CIVIC
160,000 MILES • 4 CYL • FWD • AUTOMATIC
DJQCOOKIE
My RPM was going low when I start the car, so I flushed out the radiator fluid a week ago, because it was color brown/peach. and about now it has changed color again, and the horn does not work. I checked the fuse,it was ok. help me please...
Mar 14, 2010 at 7:26 PM
  • 31,937 POSTS
Hi there,
You will have to check the transmission for water, as you may have a cracked transmission oil cooler, you will have to check for 12V at the horn with the button pressed, if you have voltage the horn will be faulty, start here.
mark (mhpautos)
Mar 14, 2010 at 9:13 PM
