1992 Honda Civic How replace bulb
1992 HONDA CIVIC
193,000 MILES • 4 CYL • 2WD • MANUAL
BROE1B
How do you replace the head light bulib?
Sep 29, 2009 at 12:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL & INSTALLATION
Sealed Beams
CAUTION
Most headlight retaining rings and trim bezels have very sharp edges. Wear gloves. Never pry or push on a headlamp; it can shatter suddenly.
Remove the headlight bezel (trim.) It is secured by a series of small screws.
The sealed beam is secured by a retainer and either 2 or 4 small screws. Identify these screws before applying any tools. Do not confuse the small retaining screws with the larger aiming screws. There will be two aiming screws or adjustors for each lamp. (One adjustor controls the up/down motion and the other controls the left/right motion.) Identify the adjustors and avoid them during removal. If they are not disturbed, the new headlamp should be in identical aim to the old one.
Using a small screwdriver (preferably magnetic) and a pair of needle-nose pliers if necessary, remove the small screws in the headlamp retainer.
A good kitchen or household magnet placed on the shank of the screwdriver will provide enough grip to hold the screw during removal.
Remove the retainer and the headlamp may be gently pulled free from its mounts. Detach the connector from the back of the sealed beam unit and remove the unit from the car.
To install:
Place the new headlamp in position and connect the wiring harness. Remember to install the rubber boot on the back of the new lamp. Also, make sure the headlight is right-side up.
Have an assistant turn on the headlights and check the new lamp for proper function, checking both high and low beams before final assembly.
Install the retainer and the small screws that secure it.
Reinstall the headlight trim.
Replaceable Bulb
Locate the bulb cover and slide it back on the wire.
Unplug the connector from the back of the bulb.
Twist the lockring or release the retaining spring and pull the bulb holder from the headlight housing.
Do not handle quartz halogen bulbs with your bare hands, the oils in your skin will cause the bulb to fail.
Remove the bulb from the holder.
To Install:
Insert the replacement bulb.
Reinsert the holder into the housing and turn the lockring. Reconnect the electrical lead. Slide the rubber boot back into position.
Mar 6, 2021 at 9:22 AM
