1992 Honda Civic fast idle problem
1992 HONDA CIVIC
150,000 MILES • 4 CYL • FWD • AUTOMATIC
STRYDER93
i'm having an issue with fast idle. it's revving too high and i don't know how to manually reset the idle on a fuel injected motor. It's a 16 valve 1.6 or 1.5 litre. I don't have the manual. '92 honda civic cx. Thanks for any info
Feb 24, 2010 at 10:31 PM
ERNEST CLARK
  • CERTIFIED EXPERT
  • 1,730 POSTS
You shouldn't have to manually reset the idle on your engine. You either have a vacuum leak in one/more hoses, your idle air control valve is leaking, or one/more of your computer sensors are faulty.
Begin checking these in that order until you find the culprit.
Feb 25, 2010 at 8:28 AM
CUSTOMIZER 29
  • 8 POSTS
[quote:b869798098="stryder93"]Engine Mechanical problem
1992 Honda Civic 4 cyl Front Wheel Drive Automatic 150000 miles
i'm having an issue with fast idle. it's revving too high and i don't know how to manually reset the idle on a fuel injected motor. It's a 16 valve 1.6 or 1.5 litre. I don't have the manual. '92 honda civic cx. Thanks for any info[/quote:b869798098]Check for a vacume leak. Old and cracked hoses.
Feb 25, 2010 at 2:54 PM
