1991 Honda Civic Replacing Radiator
185,000 MILES • 4 CYL • 2WD • MANUAL
JOTACE07
I'm going to replace the radiator,I'd like to know some tips to do it. I got a new radiator and the coolan fluid, do I need to get any thing else??? Thank you.
Jan 5, 2010 at 12:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable.
Properly drain the cooling system into a suitable container.
Disconnect the fan motor and motor connector.
Disconnect the upper and lower radiator hoses.
Disconnect and plug the automatic transaxle cooling lines at the radiator, if equipped.
Disconnect the coolant reservoir overflow hose.
Remove the radiator attaching bolts and brackets.
Remove the radiator with the cooling fan attached.
Remove the cooling fan and shroud from the radiator.
Check all cooling system hoses for any signs of damage, leaks or deterioration and replace if necessary.
To install:
Attach the cooling fan and shroud to the radiator and install the assembly.
Attach the radiator bolts and brackets. Tighten the radiator bracket bolts to 7 ft. lbs. (10 Nm).
Connect the coolant reservoir overflow hose.
Connect the automatic transaxle cooling lines to the radiator, if equipped.
Connect the upper and lower radiator hoses.
Connect the fan motor and thermo-switch wire connector.
Refill the system with the proper type and quantity of coolant, check for leaks and bleed the cooling system.
Reconnect the negative battery cable.
Jan 5, 2010 at 12:19 AM
