1991 Honda Civic
IJAY29
  • 1991 HONDA CIVIC
  • 4 CYL
  • FWD
  • 230,000 MILES
Please may I know whats the reason why my honda civic 1991 the engine stop from running automatically and I cant turn back it on.
Friday, March 12th, 2010 AT 5:14 AM
Do below to determine if its compression, fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain
Friday, March 12th, 2010 AT 5:31 AM
