Hi friend, since the last time you reply my mail, you will not believe that my local mechanic could not solve the problem, then I have decided to take it up myself.
If you remember, it was a spark plug issue we discussed last. Since then I've been changing plugs every month, Later i discover that the air system is dirty (i cant say precisely the type of air system) I clean it up and for the rest of that month it was fantastic. But now the problem come back again. This time around I have to open the ECU and observe the LED.
When I start the engine in the morning, normally the engine will work for about to minute without load i.e no head lamp on or other things, then engine will come down with low noise and less vibration. But now the engine after 15s to 20s it will rise again and you will here the manifold vibrating.
The LED D1,D2,D3 and D4 in the ECU.
As you starting the engine D4 and D2 light up the the engine high up D4 went off and D1 lit up at this time this air system become abnormal, if you press the accelerator the engine will start to make shooting sound and slow down later went off.
On the ECU there are three plug with bunch of cable if I remove the middle plug the and start the engine LED D2,D3 and D4 come on and the engine is normal but the PGM-FI light on the dash board will not work and after 1hour the engine will not start again until I plugged in the cable plug back.
(1) Is my ECU bad (2) is there any relay that is bad (3) is my PGM-FI bad. (4) is there any problem with Idle speed adjustment.
With all this problem the engine did not soak spark plug but there are black deposit on the spark plug.
Please if there is any drowning to assist me kindly forward it to my mail box chrisletua@yahoo.com
Mar 13, 2009 at 12:18 AM
