1987 Honda Civic brakes
LBRYANT1965
Brakes problem
1987 Honda Civic 6 cyl Wheel Drive Type unknown Automatic 300000 miles
i have replaced the brake MasterCylinder + brake booster and I have pedal but no brake. I hear a hissing noise of air coming out from under dash..Will the vacuum hoses not being properly reconnected cause this?
Jan 12, 2008 at 1:36 PM
  • 31,937 POSTS
Hi there,
Disconnect the booster vacuum supply and block hose, is the noise still there, if not you have a faulty booster, a small vacuum hose off will not affect the booster, operation.
Mark (mhpautos)
Jan 12, 2008 at 1:40 PM
FISHERMAN
  • 937 POSTS
[quote:38a6113cad="lbryant1965"]Brakes problem
i have replaced the brake MasterCylinder + brake booster and I have pedal but no brake. I hear a hissing noise of air coming out from under dash..Will the vacuum hoses not being properly reconnected cause this?[/quote:38a6113cad]
Hello !!
That noise its a vacuum leak..
Did you adjusted the freeplay on the master cylinder/booster?
How about the freeplay on the pedal?
let me know...
LBRYANT1965
[quote:ccba6d606b="mhpautos"]Hi there,
Mark (mhpautos)[/quote:ccba6d606b]
Jan 12, 2008 at 3:15 PM
LBRYANT1965
[quote:813314b7ef="fisherman"][quote:813314b7ef="lbryant1965"]Brakes problem
i have replaced the brake MasterCylinder + brake booster and I have pedal but no brake. I hear a hissing noise of air coming out from under dash..Will the vacuum hoses not being properly reconnected cause this?[/quote:813314b7ef]
Hello !!
let me know...[/quote:813314b7ef]
Jan 12, 2008 at 3:16 PM
