O2 Sensor goes bad
HONDA ACCORD
RMENDOZA2202
I bought 99 HOnda Accord EX, 84K miles, one week after buying, the "check engine" light come on. I get a diagnostic done, the shop tells me the O2 sensor is bad and I need to replace the catalyst convertor ($1200). The car runs fine, does not get hot, so a friend said i probably only need to replace the sensors or I need to take the negative connector on the battery off to reset the "check engine" light. I haven't tested the battery theory yet. I live in CO, and the car was only driven in FL, the mechanic said the fuel in CO is 10% alcohol in winter and the gas just chged over, might be why the sensor went bad. I just don't know. Please advise.
Mar 19, 2007 at 12:16 PM
BRUCE HUNT
  • CERTIFIED EXPERT
  • 3,754 POSTS
The removal of the battery connection will clear the memory of the computer. Replace the O2 and see how things go. I would only take it a step at a time. See if after the O2 is replaced the check engine light comes back on.
Mar 19, 2007 at 12:53 PM
